LaserView csv files
LaserView csv files
Hello, we own a bystar4020 and we found out that the laserview system stores csv files. The names are :
- LaserSt - https://files.engineering.com/getfile.aspx?folder=...
- LaserAo - https://files.engineering.com/getfile.aspx?folder=...
- LaserBs - https://files.engineering.com/getfile.aspx?folder=...
- LaserView - https://files.engineering.com/getfile.aspx?folder=...
We would like to know what is the data inside them. There is a date, time and bits state, but we don't know what those means. We would like to use this data to do productivity evaluation. The Laserview Version is P8806.
Thanks!
Thanks!
RE: LaserView csv files
TTFN (ta ta for now)
LaserBs appears to be counting a bunch of things
LaserView is a log file, presumably of things that happened on the machine, 69 of them on 1/29/2021, and so forth.
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
Thanks a lot!
