Contact US
Dynamic Tailwater for Risers
I have various SWM facilities that are outletting to stream valleys. These SWM facilities all have risers that then connect to a simple culvert or system with a single or double manhole before outletting adjacent to a stream. For these systems the tailwater is determined by the stream which is computed from a HEC-RAS model. So in the HydroCAD models the tailwater is set in a different model for each recurrence interval storm. The problem is the that tailwater is static throughout the 24-hour storm and the reviewer is not accepting this as an accurate model. Is there a way to enter a table of tailwater elevations for various discharges that way the tailwater is dynamic throughout the storm routing giving a more realistic model of the facility water surfaces and discharges.
RE: Dynamic Tailwater for Risers
In HydroCAD, you can use a LINK at the discharge location. Edit the link and set as follows:
General tab
Link Type->Internal
Elevation tab
Water Surface Elevation->Table
Check "Multi-Event"
Edit the table with the appropriate tailwater data for each event.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
