Contact US
Pipe Labelling
Pipe Labelling
Pipe Labelling
Is it mandatory in the US to place labels to ID service & flow on pipes in Polyethylene plants?
RE: Pipe Labelling
I dont think so, but why would you not do that?
RE: Pipe Labelling
IMO, the piping system identification is one of the OSHA requirement, and may be adapted by the Plant Owner.
RE: Pipe Labelling
It is nearly impossible to write Haz Ops without labeled piping.
RE: Pipe Labelling
There isn't even a uniform system, each standards organization has their own labeling code.
RE: Pipe Labelling
I'd even paint them different colors.
RE: Pipe Labelling
Don’t forget OSHA’s general duty clause. Even if there is no specific law, if an incident occurs in such a way that a lack of clear labeling contributed to the incident, it will be held against you under the general duty clause.
RE: Pipe Labelling
As mentioned above, it is foolish NOT to clearly (paint for example) label each system's piping and every valve operator.
Training, repair, maintenance and shutdown work (by contractors and scaffolders and millwrights and pipefitters and other outsiders to the plant!). Startup, shutdown, adjustments, are ALL more reliable when the systems are clearly defined.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
