Pipeline isolating device: Is there anything newer or better?
Hi everybody
I'm looking for the art's state about Pipeline isolating devices.
I see the typical and well known Monoblock joints and/or flanged joints, but someone knows about some improvement in this technical or any better or newer device to isolating catodically protected pipelines?
Thanks in advance
Thanks in advance
RE: Pipeline isolating device: Is there anything newer or better?
What sort of improvement or "better" did you have in mind?
I think these are in the box of "If it isn't broken why fix it?"
I'm not looking for an specific improvement. But it has been the same for a long time.
I was reviewing the standards: NACE RP 0286 becomes SP0286 in 2007 and it has been all about it.
As you say: If it isn't broken why fix it?
MONOLITHIC INSULATION JOINTS
https://stantonsales.net/pipeline-insulated-joints
Best located where bending moment is low, i.e. not on a gooseneck at a pig launcher or receiver.
