Dear all,
In a torrefaction system (oxygen-free thermal conversion of biological material) I am looking for a applicable pressure measurement. However, there is an interesting combination of process factors, that make this measurement challenging:
Operating Range: roughly -50...+50 mbar (pressure needs to be maintained at minimum overpressure, like +1 mbar)
Operating temperature: 300-350 degC
Medium: Gaseous mixture, consisting of steam, CO2, CO, condensables (with boiling points of up to the actual process temperature)
The main challenge I'm facing is the fact that the applicable pressure transmitters in this pressure range cannot withstand the process temperature. However, cooling the medium (and/or sensor) triggers condensation and therefore contamination of the sensor or the tubing leading up to the sensor.
I am currently looking into a measuring device with a continuous, small flow of nitrogen through it, but I am not convinced this is appicable.
Looking forward to hear thoughts on the matter! Thanks in advance!
Best regards,
Jan Oltvoort
Best regards,
Jan Oltvoort
