distance between gas pipe line and sewagw pipe line
hello sir, good afternoon everyone , i wanted to know what is the safe distance in underground crossing between gas pipe line and sewage pipe line? with some evidance(pdf) . can you help me?please
RE: distance between gas pipe line and sewagw pipe line
"Safe" is in the eye of the beholder. The gas pipeline owner will want the separation to be as big as possible.
A lot depends on who is there first and what rights they have in each countries laws and regulations or land rights.
Typically you see distances of between 0.5 to 1m separation, but it is very variable.
Some more information would help a lot.
I suggest starting with researching local jurisdiction code and if that does not provide a specification, checking with the gas and sewer utility owners.
its usually not an issue since sewerlines are usually much deeper than gas lines
https://rga.lis.virginia.gov/Published/2000/SD24/P....
But the OP needs to define "safe". Safe for who? How "safe". It is a meaningless set of words at the moment.
