SteelPE
- Mar 9, 2006
- 2,759
I have this project that is currently at the end of the design process. Code is IBC 2015.
Due to issues with the exiting conditions (this is a mezzanine going inside an existing building) I can't get framing into the column in the orthogonal directions. Column is a W18 due to the fact that the mezzanine is planned to be extended in the future and this column will become part of a moment frame. Currently the column has 14 kips in axial load and is approximately 21' tall.
We are proposing to to brace the column back to the new mezzanine with a HSS "strut". I don't inherently see anything wrong with what I am proposing, but I don't exactly feel comfortable with it either. Is there anything I should be doing to this column?
