Jan 7, 2021 #1 Bartonrj25 Mechanical Joined Oct 24, 2008 Messages 12 Location US Is it bad practice to add a section view from a detail view or does it matter as long as your design intent is captured?
Jan 7, 2021 #2 MJCronin Mechanical Joined Apr 9, 2001 Messages 5,102 Location US Bart ... This is typically a matter of company policy.... but can sometimes be set by the CAD software in use Wisely, DASSAULT's "SOLIDWORKS" establishes definitions and makes policy (de facto) by the way that their software works https://help.solidworks.com/2018/en...rks/c_broken_out_section_view_detail_view.htm https://help.solidworks.com/2017/en...e a detail view,view, or another detail view. Some software packages (SIEMENS) specifically discuss section views taken from Detail views (see page 3-32) https://support.industrysoftware.au...raining/se/en/ST4/pdf/spse01545-s-1040_en.pdf MORE INFORMATION !!!! ..........Give us a detailed example of your probem.... tell us more about your specific issues !!! MJCronin Sr. Process Engineer Upvote 0 Downvote
Jan 7, 2021 #3 SnTMan Mechanical Joined Jan 22, 2005 Messages 6,855 Location US Bartonrj25 said: Is it bad practice to add a section view from a detail view or... Click to expand... It is bad practice to add any view that is not needed to fully undertsand the subject of the drawing. Regards, Mike The problem with sloppy work is that the supply FAR EXCEEDS the demand Upvote 0 Downvote
