standard of ERW Fitting
Hi guys,
I have question about standard of ERW fitting
As I know standard of seamless fitting is ASTM A234, so how about standard of ERW Fitting?
please help me to find this issue, I have to find the answer in order to cooperate with factory and my clients
Thank you so much
Thank you so much
RE: standard of ERW Fitting
The ASTM A234 Standard includes both seamless and welded pipe fittings
For seamless steel pipe fittings refers to the raw material from the seamless steel pipes and tubes; Similarly welded steel pipe fittings covers the fittings raw material from welded steel pipes.
Consider reposting in the "Pipelines, Piping and Fluid Mechanics engineering" forum
Tell us more .... Is an evil client MBA trying to force you do do things against your common sense and professional judgement ?
MJCronin
Sr. Process Engineer
