I am doing a project, in which I am running the Abaqus simulation through python scripting.
I have some experimental values and I am using these values to get some initial assumption. Then these initial assumptions are used as input in Abaqus simulation, after running the simulation the output i.e. the simulated values are compared with the experimental one that I have used to generate the input.
So after comparing experimental and simulated values I will get some error. I want to reduce this error by optimizing the input values of the simulation.
I am not getting any idea, how to optimize these input values in order to reduce the error in a certain limit.
Please suggest the possible solution to this query.
I will definitely appreciate any suggestions.
Thank you.
Thank you.
