Contact US
Differences in results using SHELL EQUIVALENT SECTION
Hello everyone, by performing the modal analysis of this wing model that has a dihedral angle of 10 °, in which I defined the thicknesses of each node of the mesh through a spatial field and then use a SHELL-EQUIVALENT SECTION property, I noticed a strong difference in the results compared to the 3D model. I had not encountered this problem in previous analyzes where the wing did not have a dihedral angle.
When I speak of diversity in the results I mean that the frequencies of the first 4 modes of vibrations go from having values of 20Hz-50Hz-80Hz (modal analysis with 3D model) to values of 180 Hz-350Hz-500Hz (modal analysis with 2D model).
I have already used this method in other analyses with wings of the same geometry (but without dihedral angle) and material, obtaining excellent results compared to 3D.
I am sure that the analysis with the 3D model is right because the values of the modal frequencies are close to those obtained previously for the same wing without dihedral angle.
The wing in question is made of Mahogany (2D orthotropic material).
Could it be that this type of method has problems when the plate does not lie on the XY plane?
In image 1: you can see the dihedral angle imposed
In image 2: you can see the plate (i.e. the wing)
In image 3: using the display shell thickness I show you the real geometry
In image 4: the settings used in the SHELL-EQUIVALENT SECTION property
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
