How to minimize cost function define over volume omega using BFGS algorithm? 1
Lemine
FR
Hello, Engineer and Mathematician programmer,
I have computed a cost function J(x1,..xn) and her gradient J'(x1,..xn) defined over a volume using finite element analysis.
so I have the value of these fields J and J' at n nodes (x1,..xn) in the geometry (integration point) and I have saved the data in a text file.
My problem is how to minimize this function using for example BFGS algorithm?
Thanks for your help
Well, a cost function is something we want to minimize. For example, our cost function might be the sum of squared errors over the training set. Gradient descent is a method for finding the minimum of a function of multiple variables. So we can use gradient descent as a tool to minimize our cost function.
3DDave, I suspect its a bot poster or similar, since posts are starting to come up with a link in the signature.
