trenie pipes cpncreting
MANKIND77
1
i have been facing difficulties disconecting tremie pies wire ropes
is there a special kind of grease required
Are you sure you are using the right wire ropes ? Connecting parts and wire ropes are designed as a whole with very strict tolerances. You should not use replacement wire ropes which are not strictly the right ones. If you are using tremie pipes longer than 70 m wire ropes get smashed because of the weight and screwed connections should be used.
