Contact US
Error when getting Python to attach to ETABS
Hi, I'm using the following code:
import sys
import comtypes.client
try:
myETABSObject = comtypes.client.GetActiveObject("CSI.ETABS.API.ETABSObject")
except (OSError, comtypes.COMError):
print("No running instance of the program found or failed to attach.")
sys.exit(-1)
SapModel = myETABSObject.SapModel
I'm getting an attribute error:
AttributeError: module 'comtypes.gen.CSiAPIv1' has no attribute 'cOAPI'
Does anyone know how to fix this?
I'm using Pycharm, ETABS v18.
RE: Error when getting Python to attach to ETABS
Hi. Thanks for the reply! I actually saw this thread before posting but I don't really understand what the __init__ file is doing. Are you able to provide any context? Do I need to have that at the beginning of my code? It seems Bjorn managed to fix his issue but didn't explain why.
I can't say I completely understand the usage of an __init__.py file for python packages.
What comtypes version are you using. When I first started using the etabs API with python early in 2019 I was using comtypes version 1.1.2, that was giving me some trouble and I had to change a little bit of the __init__.py file to get it working, I remember it being something like a try block with no exception catch. However, many of my colleagues started using my scritps and they where using comtypes 1.1.7 (still current release). Now, I think there are still some bugs with this version of comtypes, I still get errors when trying to get modal output. Will try and did into it a bit further. But what version of comtypes are you using.
I am working in comtypes 1.1.7. I actually switched to Anaconda instead of Pycharm and it seemed to fix the issue, I have no clue why.
Same here, one of my colleagues also had the same issue and I can't work it out but think it has something to do with the file that get's generated in the comtypes.gen folder. Best fix I found is uninstall and re-install.
How are the scripts going, I see by some of your other posts that you are looking to write a few custom functions to automate your workflow?
Quote (rscassar)
First code I'm going to write it to take raw coordinate data from Revit (using a dynamo script) and then develop a python code that will build a model with the geometric data in ETABS. I think it will be a good project to develop an understanding of the API. Then I'm not sure which direction I will go, I feel like understanding ETABS API will open a lot of doors for automation!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
