How does running a large motor at a low torque affect accuracy
joaquinj
I am designing a test rig that uses a brushless servo motor for load testing. There is a large range of tests that need to be performed, and I am trying to find a motor that does it all. My question is, if I am using a motor that is rated for a nominal torque of 2000lbf-in, and want to use it for a test where the required input torque is 200lbf-in, will the motor accuracy deteriorate significantly from doing this?
Accuracy? Do you mean efficiency?
I mean accuracy. Will the motor be able to accurately apply a torque much lower than its nominal rating. aka, can a motor rated for 2000lbf-in accurately provide a torque of 200lbf-in.
Define "accurate". What type of motor? What speed? You are not going to find a brushless servo motor that will deliver 2,000lb-ft of torque. At 1800RPM you are looking at almost 700HP. (Edit, never mind... I see my mistake. lb-in. Sheesh.)
A servo motor can have it's torque CONTROLLED by virtue of servo amplifier, which can limit the output torque from 2,000 lb-in to 200 lb-in, and in doing do it can probably hold it there at +-2%, maybe a little better.
"You are not going to find a brushless servo motor that will deliver 2,000lb-ft of torque."
I believe the OP stated 2000 lbf-inches.
Walt
The torque output of the motor, up to the motor's maximum, is entirely dependent on the load. Provided your load is accurate, the motor will be too.
Or are you trying to limit the torque?
Jeff, Is that 2% of 2000 in-lbs or 2% of 200 in-lbs?
Bill
"Why not the best?"
Jimmy Carter
