Spiral Wound Gaskets for Thin Wall pipes against ASME B16.20 Table SW-2.5-2 & SW-2.5-1
ET1983
IN
Dear Pipers,
Came across a request from 'End-User' to the use of 'Spiral Wound Gaskets with Inner Ring_ASME B16.20' in place of existing 'Flat Ring Gaskets_ASME B16.21'.
It was briefed on the limitations for the use of "Spiral Wound Gaskets with Inner Ring_ASME B16.20" to thin wall pipes, in accordance to Table 15 & 16 / Table SW-2.5-2 & SW-2.5-1, which is considered to be a potential problem for inner ring to extend into the pipe bore under the worst combination of eccentric installation and additive tolerances.
Though it was justified to 'End-User' to negate the use of SPW-Gaskets ( for schedules & bores not in compliance to ASME B16.20 requirements), couldn't warrant that with any evidence, as few of the international recognized standards (SHELL, TOTAL specs) were defined with SPW-Gaskets for thinner pipes (lesser schedule pipes_10S) in their latest specifications.
Is the use of 'Spiral Wound Gaskets with Inner Ring_ASME B16.20' a potential concern as defined in the codes (or) any exemptions are made available for its use on thin wall pipes?? Please advise.
Pipers,,,Can you throw some light to the query??
Groove your flanges. You can use spiral wound gaskets and be supported on both sides without interference with the flow.
