Contact US
Roughly Calculating thermal losses
Hi all,
Im currently woring on an improved heat exchanger which essentially is a block of t6 aluminium with an array of vertical Quartz tubes passing through (Block essentially has clearance holes which tubing pass through). fluid enters a fluid manifold at the bottom, travels upward and exits on the top of the assembly thorugh a mirrored fluid manifold.
Block is heated by cartridge heaters.
In theory I roughly have around 3.8 times more tubing surface area contact than existing design, so in theory it should out-perform our current design by quite a bit.
However I want to get a feel for thermal losses, currently there is no blanket or shoud around the heat exchanger so obviuously it is goign to be emitting a substantial amount of heat.
I do plan on introducing a blanket of some sort, but for the moment, i would like to get a rough idea of what thermal losses i should expect.
Can anyone help point me in the right direction ?
Thank you
R
RE: Roughly Calculating thermal losses
You're trying to heat (or cool) something. Why not measure it's temperature pre- and post- heat exchanger ? "all" you care about is the useful heat transfer, what does it matter is heat is being lost somewhere (unless you're trying to heat something) ?
So this is just a block of aluminum in free air? For steady state, you would just need to calculate the convective heat transfer. Problem is getting an accurate heat transfer coefficient.
1) this should be in the heat transfer and thermodynamics forum (have you looked in there for answers)
2) for anyone to help you you need to provide some drawings / sketch / dimensions and some data on temperature, heat input / electrical input, flow rate, mass of the block etc.
3) when you out perform what do you mean? Heat transfer? heat output?, efficiency? What has changed form the original design? If you don't change the number of cartridges
4) Is heat loss convection? conduction? forced air? still air?
It all makes a big difference.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
