Cutback Bitumen
sepiddeh
DE
Dear friends,
Anybody here knows about asphalt or bitumen cutback? I need cutback bitumen and I want to simply add some solvent to bitumen 60/70. Do you know if it works? and can you tell me which type of solvent can I use?
What is your use? There are numerous forms of cutback asphalt, depending on your end use. The type of solvent depends on whether you want rapid cure (solvent evaporates quickly), medium cure, or slow cure (less volatile solvent).
