Anchor rod welded on plate CAN/CSA
Hey Guys,
I have the case where the anchor rod needs to be welded on the column cap plate, and it's to be welded using the full tensile strength of the rod. Plate material is 300W with 1" thick and Anchor rod material is A307 with 1"Ø, What will be the fillet weld size? I know fillet weld size for rebars but not for anchor rods.
Thanks in advance!!
RE: Anchor rod welded on plate CAN/CSA
This thread may help. Link
Quote (r13)
The case I have is different than the thread, Can I get anything else
Thanks in advance!!
If you need to develop the full strength of the rod, then your fillet size will be the weld circumference (all around the rod) x the weld throat (0.71 x leg height) x the allowable weld strength. You might need a partial penetration butt weld in addition to the fillet to develop the full strength of the rod. Run the numbers.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Functional Prototyping Using Metal 3D Printing
Functional prototypes are a key step in product development – they give engineers a chance to test new ideas and designs while also revealing how the product will stand up to real-world use. And when it comes to functional prototypes, 3D printing is rewriting the rules of what’s possible. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
