How to choose the most suitable materials? 1
dangchung
Student
VN
Hi all,
I want to ask about the chemical resistance, I saw an online tool (link: showing the resistance of Santoprene against hexyl alcohol is only B-rating, and it is A-rating for Teflon.
However, when I tried to ask an AODD pump salesman, he told me that I have to use A-rating materials.
Is it correct?
When I read a chemical resistance guide, there is a paragraph like this: "Neoprene or Wil-Flex™ diaphragms should generally be used unless the chart shows them to be unsatisfactory. Even though Buna-N, Nordel®, and Viton® may show “A” ratings, if neoprene or WilFlex™ have at least a “B” rating, it will probably be the most economical choice on a “cost of diaphragms per gallon pumped” basis."
So what should I choose?
Thanks.
That depends on the application. If maintenance or failure is mission critical, go for A. If cost is important then B might be better. If all these issues were obvious we wouldn't need brains, just salesmen.
Cheers
Greg Locock
