subroutine tabva2
VzHache
FR
I am trying to use the subroutine forcem that calls tabva2.
I'm facing with strange behaviour I do not understand.
A table that aims to increase linearly the load is included in the bulk file:
table table1
1 1 0 0 2
1 2 1 0 0 1 0 0 2 0 0 2
0.000000000000000+0 0.000000000000000+0
1.000000000000000+0 1.000000000000000+0
Then, the forcem subroutine is called for the application of pressure:
dist loads
1 1 0 0 0 0apply3
1.000000000000000+1
1
0 1
13
apply3_edges
My calculation is done in 4 increments: 0.25, 0.5, 0.75, 1.
I would like checking thevalue send back by tabva2 subroutine and introduced the following lines in the forcem:
write(6,*) "Check table"
do x=0,1.,0.5
call tabva2(x,P1,1,0,0)
write(6,*) x,P1
enddo
Here is what I got:
increment 0:
Check table
0.000000000000000E+000 0.000000000000000E+000
0.500000000000000 0.000000000000000E+000
1.00000000000000 0.000000000000000E+000
increment 0.25:
Check table
0.500000000000000 0.125000000000000
1.00000000000000 0.250000000000000
increment 0.5:
Check table
0.500000000000000 0.250000000000000
1.00000000000000 0.500000000000000
increment 0.75:
Check table
0.500000000000000 0.375000000000000
1.00000000000000 0.750000000000000
increment 1.:
Check table
0.500000000000000 0.500000000000000
1.00000000000000 1.00000000000000
With that results, the load factors considered in forcem (and coming from table 1) are:
0.25=>0.0625
0.5=>0.25
0.75=>0.5625
1=>1.
and not
0.25=>0.25
0.5=>0.5
0.75=>0.75
1=>1.
Can anybody explain me why the values coming from tabva2 differ from increment to another and do not match with the table?
Many thanks in advance for your support.
VzHache
