Eurocode groud type S1 seismic action
ramihabchi
LB
Can someone give me example on how to determine seismic action for type S1 ground in eurocode?is determining shear wave velocity by site investigation and then choosing ground type(from A to E) based on tbe corresponding range is right?
Are you asking for ground types A-E or ground types S1 and S2 (special ground types)?
If you're asking about the actual procedure, you're probably better off asking in geotechnical engineering general discussion forum.
If you're asking what the code says, it's the following.
For S1 this is the case (copied from the code):
Deposits consisting, or containing a layer at least 1O m thick, of soft clays/silts with a high plasticity index (PI> 40) and high water content.
vs30 < 100 m/s (indicative)
cu 10 - 20 kPa
For sites with ground conditions matching either one of the two special ground types S1 or S2, special studies for the definition of the seismic action are required. For these types, and particularly for S2, the possibility of soil failure under the seismic action shall be taken into account.
NOTE Special attention should be paid if the deposit is of ground type S1. Such soils typically have very low values of vs, low internal damping and an abnormally extended range of linear behaviour and can therefore produce anomalous seismic site amplification and soil-structure interaction effects (see EN 1998-5:2004, Section 6). In this case, a special study to define the seismic action should be carried out, in order to establish the dependence of the response spectrum spectrum on the thickness and vs value of the soft clay/silt layer and on the stiffness contrast between this layer and the underlying materials.
