BACKGROUND: We are in the process of updating our CAD drawings to enable us to out-source production of various components. Many of our components have a similar issue: we have a shaft that runs through two steel ball-bearings pressed into a machined piece of aluminum. As per various bearing manufacturers specs, it is important that the inner and outer rings of the bearings are aligned (i.e. bearing manufacturers typically specify a maximum misalignment between inner and outer rings of < 10 arcmin). Assuming a perfectly straight shaft, then the location of the two bearing holes relative to each other in the part will control the orientation of the inner rings.
QUESTION: What tolerances on the bearing holes are necessary/best-practice to control the orientation of the outer rings of the bearing after assembly? Should the orientation of the short walls of the housing bore be controlled, (i.e. parallel to the main axis of the shaft) or should the orientation of the housing shoulders on which the outer race sits be controlled (i.e. perpendicular to the main axis of the shaft). Or both?
POSSIBLY RELEVANT MATERIALS/SPECS. Typical bearing sizes we use are for 10-25 mm diameter shafts (e.g. bearings 6900, 6205). Bearings are typically spaced 50-100 mm apart. We typically use interference fits (e.g. M7). Ball bearings are deep-groove, steel. Material of machined parts is aluminum.
INITIAL THOUGHTS: From a theoretical perspective, my assumption is that the orientation of the housing shoulders is more important than the orientation of the housing bore simply because that surface is much larger. For example, with a 6900 bearing the housing shoulders present a 22 mm diameter surface, whereas the housing bore is only 6 mm long. Does that make sense? Even if it does make sense, from a practical perspective, our machinist suggested that it didn’t matter whether the tolerance on the orientation of the housing bore or housing shoulder was specified, because it would be impossible to make the housing shoulders non-perpendicular if the housing bore was parallel, and also that it would be easier to measure/confirm of the housing bore was parallel, rather than the housing shoulders. Again – does that make sense?
