Referencefor a Beam-to-column moment connection with a sloped beam?
see the attached picture,
I designed a regular 90 degree WF to HSS moment connection via a cap plate. Turns out now my boss wants a slight pitch to the roof maybe about a 2" height difference between the front and back face of HSS column (see image). My question is can I reuse this same connection (shown in the image). It seems like it would look rather odd sloped. Do I need to account for any changes to me conection calcs aside from the slope giving the beam some compression?
also if this connection is no good, does anyone have any references out there for commen sloped moment connections :(
RE: Referencefor a Beam-to-column moment connection with a sloped beam?
This came up recently in another thread if you can find it.
