Matlab 'for loop' help!!
biaozhun
Student
JP
I need a for loop to pick numbers to be saved in an existing matrix, the matrix is the same size as the amount of data (non square). The sequence in which the numbers have to be picked is as shown in the image below. It starts at the dot and follow the arrows to see the order in which numbers should be store.
Maybe it is a simple question but I am stuck, so please help me[love]
I doubt you'd use a for loop for that
I'd do the first three by saying
newmatrix(3)=weird_dot_value
newmatrix(6)=oldmatrix(3)
newmatrix(9)=oldmatrix(6)
and so on
//ok there is some structrue there you could put in a loop
for ii=1:12
%stuff goes in here with modulo arithmetic or lots of test cases
end
Cheers
Greg Locock
