thread712-150103
I am wondering which solvent is best for use with plastic that is a mix of ABS and PC. I understand that acetone is a wonderful ABS solvent used often in 3D printing and plumbing but the only information I can get regarding acetone and PC is that it swells PC plastics, causing damage but not melting them. Which solvent would work best for use on both ABS and PC, and am I misinformed regarding the effects of acetone on PC?
