Decimal Accuracy
Decimal Accuracy
I continue to hang out and mostly lurk in an editor's facebook group. I have been accused of mansplaining during a discussion of metric conversions. I have claimed that 4.5 miles converts to 7.2 km, not 7.24 km.
Is there a documented, formal standard that dictates decimal accuracy?
Is there such a thing as a style guide for engineering calculations?
JHG
RE: Decimal Accuracy
B.7.2 Rounding converted numerical values of quantities
Example: To express the value l = 36 ft in meters, use the factor 3.048 E−01 from Sec. B.8 or Sec. B.9 and write
l = 36 ft × 0.3048 m/ft = 10.9728 m = 11.0 m.
TTFN (ta ta for now)
Thank you. That is exactly what I needed. I would give you are star, but the button is not visible in this forum or on this thread.
Here is an interesting link someone put up: Significant Figure Rules Penn State University.
JHG
if it were a math/engineering forum you could say the input is 4.5 miles +-0.05 miles so the answer is 7.24km +- 0.08km. You might say the input has only 2 significant digits so the output should too. I'd've said the increase in "accuracy" of the output is due to the translation of the units.
quit hanging out where you don't belong !
Hard to argue that 7242.0 m is not 7.242 km
Anyway, you are right. You will not convince anyone. It probably won't make any difference to the world.
The issue is that the original number, 4.5 is clearly an approximation itself, so could be 4.4 or 4.6, but not 4.55
So the implied error of up to 0.05 miles shouldn't then imply a greater accuracy in the translation. yes 4.5000 miles is 7242m. but then it wasn't 4.5000, it was 4.5. So it could have been 4.5462miles which would then be 7319m (7.3km or 7.32km). so to stay true to the original accuracy 7.2 will be correct.
It's always annoyed me when what is clearly a nominal number in one set of unit is then magically translated as some mega precise number in another set, instead of rounding up or down to make it the same accuracy or the same nominal value. So e.g. 12" NPS becomes 300NPS and not 304.8 NPS.
The numbers might not be accurate, but a sign I read recently said that this area of parkland was 2000 acres (clearly a rough total), but then in brackets it had something like (4064ha). Now 4,000 would have been a much better number IMHO and it's good to find something that expresses this in a scientific manner.
Pedantry goes both ways.
This does provoke funny letters to the editors of newspapers.
JHG
Exactly my point - I assume this was a "standard" 400 lb bear, +/- 50 lbs.
So I assume this really now should be a 200 kg bear unless it is rather thinner nowadays and is a 150kg bear...
I’ll see your silver lining and raise you two black clouds. - Protection Operations
then is 0.125" more accurate than 1/8" ? if its 0.12" then is the error +- 0.05" or 0.06" (closer to 1/16") ?
there's more than enough pedantic-ness to go around ...
Alternatively, you can grab the bear, wrestle him into submission, and weigh him.
JHG
B.E.
You are judged not by what you know, but by what you can do.
Surely you mean "pedantry"?
(Sorry - I couldn't resist the urge to be pedantic - pedant that I am! )
http://julianh72.blogspot.com
I think pedanticism would be a better choice.
(2B)+(2B)' ?
Is it a legitimate complaint of being condescending, or is it an ad hominem attack to beat you in the argument?
Possibly just bad phrasing, etc., but he clearly understood the condescension dripping from that impromptu comment. Nevertheless, troglodytes still exist.
Now, I'm an equal opportunity mansplainer, I'll mansplain to men or women
Imagine if I (middle aged male with a buzzcut) walk into a salon to buy a gift for my wife. The employee would instantly realize she's probably not dealing with a guy who pays attention to his hair like Fabio would. She'd have to womansplain to me what the latest and greatest products are. I should be more sensitive so that I can detect when I should be offended.
The issue at hand, at least when I hear about this, is about the frequency of contexts in which women feel they are talked down to.
So yes- you at the salon is a reasonable example. But for a lot of women they can receive that type of treatment at mechanics, with repair people, at stores selling technology, at hardware stores etc etc etc. It's a real thing.
I am trying to find the Facebook thread. I noted that I am unable to Womansplain. I recall that a woman ("woman here") provided the link to Penn State.
Let's face it, mansplaining is fun. You do need to be correct.
JHG
https://xkcd.com/1716/
Neither. The question is as clear as it would be on an exam, where you will not be allowed to ask questions; thus, you are forced to actually answer the question. I understand how hard that is for engineers.
Pi, accurate to 10 significant figures, is 3.141592653
If you told me pi = 3.14 I would call that correct, because the true value is found between 3.14 + 0.01/2 = 3.145 and 3.14-0.01/2 = 3.135
If you told me pi = 3.1, that would also count true, since pi > 3.05 and < 3.15.
If you told me pi = 3 you would be correct, since pi lies between 2.5 and 3.5
If you told me pi = 3.0, then no, that's wrong, because pi is not found between 2.95 and 3.05
I assume you meant: "Number of significant digits always implies a corresponding
accuracyprecision."============
--Winston S. Churchill
Did you truncate that? That last digit is typically 4 --> 3.14159265358979
3.141592653589793238462643383279502884197169399375105820974944592307816406286208998628034825342117067982148086513282306647093844609550582231725359408128481117450284102701938521105559644622948954930381964428810975665933446128475648233786783165271201909
Steve
