Opposite of beheaded
It is not really the opposite - it is chopping off the opposite end. I'm looking for a way of describing text that has the top and bottom are not visible. Basically
hay looks like nav
Initially I was thinking of topped and tailed but not sure whether that sounds right or not in this context.
Then I thought maybe beheaded and betailed but that didn't sound right. Probably no such word as betailed or befooted.
RE: Opposite of beheaded
Depoliticized
Beheaded is not a technical term, per se; it describes the removal of someone's head, typically by sword or axe. As such, there is no corresponding term for the act of removing someone's feet or rear.
TTFN (ta ta for now)
I'd use the typographical terms: ascender & descender. lost, missing, truncated, deleted, omitted ascenders and descenders.
rectified?
Shaved top and bottom?
Sans-... sounds printy enough. I think I'll use that.
Just think, there was a time when someone said, "How do you call a font that removes the flourishes at the tips of letter strokes?". Someone replied "Those flourishes are called serifs, so I guess sans-serif", and BAM! sans-serif font was born.
Andrew H.
www.MotoTribology.com
'Sans-serif' sounds a lot better than 'without-flourishes' winky smile
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
xwb,
The UNIX commands for reading text are head and tail, although this sounds like the opposite of what you are doing.
JHG
The text was "cropped".
"de-prefixed" and "de-suffixed"?
I’ll see your silver lining and raise you two black clouds. - Protection Operations
TheTick, I almost diode laughing at that one.
My glass has a v/c ratio of 0.5
Maybe the tyranny of Murphy is the penalty for hubris. - http://xkcd.com/319/
I was going to say reheaded...
As in putting the head back one. LOL
David
Connect with me on LinkedIn. http://lnkd.in/fY7-QK
I think you had the perfect description in your original post.
Quote:
text has the top and bottom are not visible so that 'hay' looks like 'nav'
Wading?
A.
I didn’t get the example at first. It’s the removal of the ascenders and the descenders.
Quote (typically by sword or axe)
or with one of my projects, a snowmobile bridge...
Trimmed top and bottom.
with brain
luis
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
