springwaterbr
Materials
Many tubing manufacturers recommend a minimum wall thickness for tubing used in gas service. The reasoning behind that is that a heavier wall has a greater capacity to resist ferrule actions and coin out defects that might enable a leak path for gas molecules (for example, Swagelok's catalog:
My application will use welded tubing and tubing fittings. I haven't however seen an explicit exemption from this recommendation anywhere for this case. If there is no reason for a heavier wall other than resisting ferrule action, it is my understanding that once ferrules aren't employed, the lighter wall could be used, correct? Or is there is still some other motive that cautions against using lighter wall tubing for gas service, even if welded?
Thanks.
Thanks.
