High Speed Shaft Balancing without 4-Run Balance Method
Hello everyone,
I have a high speed shaft which turns around 30.000 rpm. Normally I am using 4-run method but this method is time-consuming me pretty much. I know it is quite useful but It is quite time wasting, I mean one reference run + 3 times with changed position of trial mass is hard to do in my application. Do you have any suggestion to accomplish this process with additional sensor or application? I am just using vibration data from the shaft but I can use any sensor or application in my system.
Thanks in advance.
Thanks in advance.
RE: High Speed Shaft Balancing without 4-Run Balance Method
What electronics do you have available? Oscilloscopes, etc?
What is the nature of the "vibration data from the shaft" ? Overall, filtered 1X rotation , something else?
Cheers
Greg Locock
@Tmoose Thank you for the answer. It has been solved!
Walt
