Cement Lining for Ductile Iron Pipes vs Carbon Steel Pipes
Hello All,
In AWWA Standards, the cement lining thickness specified for Carbon Steel Pipes is more than that specified for Ductile Iron Pipes (almost double).
Can anyone explain why?..
Is it because the resistance to corrosion for Ductile Iron material is more than that of Carbon Steel ?
SDTH
RE: Cement Lining for Ductile Iron Pipes vs Carbon Steel Pipes
I think so yes and also the DI tends to be thicker than C Stl so any corrosion takes longer to create a hole.
It has mostly to do with stiffness, the thinner steel pipe requires more liner for good integrity.
Thank you,
I would like to know if the reason is stated in any white paper, guide or similar publications..
The standards also don't provide any basis for the thickness.
Probably derived from practice.
I didn't see any details mentioned in DIPRA publications also.
SDTH
the steel pipe is much more flexible. often there is a mortar coating on both the exterior and interior (CML&C) this makes the pipe significantly stiffer which protects the coating from cracking
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
