Gunstein30
Industrial
im working in heat recovery boiler project.
And need to install pressure transmitter in a ducting.
Media inside ducting : Hot Clean Air (200-400 deg C)
Pressure to be measured : 0 - 1000 mbar (From Blower Specification)
This hot air is comes out from exothermic process and using blower to dissipate the heat to atmosphere.
Since the media is hot air with temperature max.400 degree Celcius, and pressure to be measured only up to 1000mbar or 1 barg. It was difficult to find the correct method for this.
How to install such kind pressure transmitter in such kind of condition?
Jason Fernandez
Jason Fernandez
