How do I save an assembly, without updating the components? 1
borsht
268
I am making an assembly file which I am using strictly for evaluating clearances, and need to keep the file for reference. I have three sub assemblies in it, and I am not going to change them, or their components at all. I have started the assembly, placed the three subassemblies in it, and fixed them in place. The subassemblies and components of them are older version files. When I go to save the new assembly I get told Older Version file, and saving will convert the files tot he current version. Is there a way I can override that so the parts wont be updated?
SolidWork Newbie since 2001
-Currently using SW2017
Inventor Newbie since 2019
-Currently using Inventor19
Have you tried saving the file(s) as a STEP or IGES and working with those instead?
Open them read only. Change your Tools->Options->System Options->External references->Do not prompt to save read-only documents.
#Handleman, I'm not familiar with inserting assemblies as read-only. This is what I've tried: I started an assembly, I opened one existing assembly read only. Then inserted it into empty assembly. I opened a second existing assembly read only, and inserted it as well. When I went to save the new assembly it told me it had changed one of the subassemblies and that it had to save it. I think you are on the right path, but can you detail the steps you would take?
You can also change them to envelope components.
ctopher, CSWP
SolidWorks '17
ctophers home
SolidWorks Legion
If you are using these just for measurements or evaluations, why not just save them under a different name and let them get updated- leaving the old files alone.
Then build the assembly with the new files.
Look up "collaboration mode".
I use this all the time. assemblies and drawings automatically open components and references as read-only. there is a toggle to open files for write-access as-needed. Saves all kinds of agony.
borsht,
Are you using any form of PDM? With PDM, you can copy files out of the database read[‑]only. If there is more than one of you in that office, and you are worried about version control, you need[ ]PDM.
Can you use Pack&Go to copy your work into a personal work directory? This will protect the original files, at the expense of leaving file copies all over the place that may or may not have been modified. This is a god awful mess somebody will have to clean up. They may be inclined to fire the idiot responsible. PDM is the better way.
JHG
