So my premium trial has expired for hilti profis. How do I get into the standard? I seem to be stuck where you select a plan, but standard is there but no button to select. Anyone use just the standard?
Their system sometimes bugs out you may need to email them if you can't get access to the basic version. They are pretty good about setting you with another free trial period when this happens though.
With the standard version you can only do concrete anchors and a rigid plate analysis for the force distribution. They do not check the bearing stress against code limits so keep that in mind if you haven't designed the plate yet and are using Profis for some quick forces, the bearing stress result is only available in the detailed report so you'll need to set that as the default in you home settings.
