Optical Encoder Axial Tolerance
I am using an Avago AEDM-5810-Z06 Optical Encoder and the data sheet (Link) lists a "Shaft Perpendicularity Plus Axial Displacement" value of 15 mm (.006") under the "Recommended Operating Conditions" (Pg.3). This is a tiny tolerance compared to some of the others on the sheet so I was wondering what exactly it was referring to and how it could cause issues if I'm not able to hold to it. It's strange because the optical wheel itself has a lot of play along the axis of rotation within the sensor assembly. Would I have to design a mount such that the shaft is held to a particular position? I'm a mechanical engineer by training so this is a bit peripheral for me.
Best,
-Shea
RE: Optical Encoder Axial Tolerance
This sets the amount the encoder is forced off center. It is large compared to the size of the encoder wheel optical measurement features.
@3DDave thank you for the response!
I had assumed it meant displacement along the axis of rotation, but based on what you're saying it's referring to the distance between the shaft axis and "ideal" axis location? With some bench-top tests I've noticed that the encoder sometimes misses a few counts, shifting the location of a column of a vertically scanned image upward. Do you think the axial displacement could cause that by moving the optical features on the wheel out of the path of the sensor light?
Thanks again,
-Shea
@IRstuff
Thank you for the input! When you say angle error are you referring to an error in the wheel angle itself or the encoder angle output? I apologize if this is relatively fundamental I am just having trouble visualizing how such a small displacement could cause such a large error.
Best,
-Shea
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
