filling a floating roof tank
Hello everybody,
I want to ask a question.
Can I fill a floating roof tank through the output nozzle?
Knowing that the output nozzle has a vortex breaker.
thanks
thanks
RE: filling a floating roof tank
Do you mean initial fill before the roof is floating or in normal operation?
A diagram / drawing would help a lot here, as well as size, flowrate, product, velocity etc, but in general you need to be carful that the flow doesn't break off the vortex breaker or result in erosion of anything or generate lots of vapour if you're doing this as part of initial fill.
And why can't you use the inlet nozzle?
We have two tanks, the first tank supplies the second tank (media pyrolysis gasoline) in the normal operation.
Currently, the plant is in total shutdown and we want to install a new radar system for the second tank.
So, we want to empty the second tank by transferring the remaining gasoline to the first tank without modification.
Operation people propose to transfer the gasoline through the existing line between the two tanks.
That is a brief description of the matter.
best regards
Thank you for your cooperation.
So flow goes fromtk1 to tank 2 Yes?
How? By gravity or pump??
You want to empty tank 2 back into tank 1.
How? Pump?
So the back flow is into tank 1 which has a fully floating roof.
If the velocity is kept pretty low (1-2m/sec) you're probably OK, but a lot depends on what the vortex breaker loos like - Do you have a drawing or can you sketch it?
So long as your roof plates are more than say 2m from the end of the outlet nozzle if it points upwards then you should be OK.
If it points horizontally then maybe even lower.
Some drawings would help!
