Contact US
High strength dielectric washer?
Hi all,
I am looking for a high strength dielectric washer (>100ksi yield)
I have a test setup of Inconel to Steel in a Salt Spray chamber.
I am aware of the potential for galvanic action and I am looking for a high strength dielectric. The force between Inconel and Steel will be max ~100ksi
Any Ideas?
I also read in the forum about LanoCote and Tef Gel as coatings.
this is a 10 day test so it doesn't have to last forever.
The Inconel is required for strength and to also not corrode in the salt spray.
I can consider alternatives to the Inconel..however they need to be very strong and not corrode.
What I am testing is the Steel under stress. Inconel is used to create stress.
Herc
RE: High strength dielectric washer?
Ceramic washers are readily available and have good dialectric properties. They can be fragile though, especially if used on surfaces that aren't well finished.
Ceramic is the only way to go with this.
How dielectric do you need?
Reach out to the CoorTek guys for info.
Thanks, I really don't know how to specify the dielectric strength needed.
Just want to break the electrical contact so I don't get galvanic action.
I will look into and let you know how it worked.
Thanks again!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
