Oct 25, 2020 #1 DieguitoI Chemical Joined Oct 10, 2018 Messages 20 Location NL In most of projects, isolation philosophy specify a vent valve between ball and globe valve in manual depressurization line, however sometimes there is not such valve. Can you explain purpose of such vent valve?
Oct 25, 2020 #2 LittleInch Petroleum Joined Mar 27, 2013 Messages 23,042 Location GB I suspect it's a function of the pressure and the isolation philosophy. Top one is clearly higher pressure and has DBB on the prv inlets. Bottom one is 8 bar and only single valve isolation Remember - More details = better answers Also: If you get a response it's polite to respond to it. Upvote 0 Downvote
Oct 25, 2020 #3 mk3223 Mechanical Joined Feb 4, 2006 Messages 1,488 Location US In the bottom diagram, is the 2"-FG-024-3091 a continuous vent line with a FO? If yes, a drain valve may not be needed as it's a sloping line. Upvote 0 Downvote
