FEMAP display of loads & constraints refresh
Hello everyone.
For some reason FEMAP doesnt want to refresh its display of loads & constraints. When i activate any loads/constraints set, the display is stuck on one particular set. Even if I create a new load set, I am not able to see it because the model only displays that one load set. I am only having this problem with one model, other models seem to update the display just fine. Anyone else have had this issue?
RE: FEMAP display of loads & constraints refresh
Not experienced this problem before, which version of FEMAP are you using?.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48004 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
Could it be that you under "Visibility"-"Load/Constraint" have selected a specific Load and Constraint Set, instead of the Active Set?
I think that I have done that by mistake at some time.
Best regards
Thomas
With FEMAP, I was still making those kinds of mistakes after 2 years of using it... :(
www.sparweb.ca
I had been working with the model all this time since the original post, without being able to see the loads that I am applying- what a pain. Thanks alot.
