Macros CATIA V5 : Create a PRODUCT from an ALL.CATPART
JordanCaron
Aerospace
FR
Hi guys,
I already have a macro to create a CATPRODUCT from an ALL.CATPART.
Unfortunately the macro replace every body in the ALLCATPART by a CATPART and add it to a PRODUCT.
Here is my issue. I have an ALLCATPART with 1000 bodies but only 3 differents geometry. So if I run my macro it will create 1000 CATPART with different axis system.
I would love to have a Macro that create only 3 CATPART and put them in position in the CATPRODUCT.
Here is the cat vba I have, but it's not usefull in my situation.
'L'objectif de la macro est de créer un assemblage multipart à partir d'une piece multi body
'Recuperation du document à decomposer
Dim les_docs As Documents
Set les_docs = CATIA.Documents
On Error Resume Next
Dim part_doc As PartDocument
Dim lapart As Part
Set part_doc = CATIA.ActiveDocument
If Err.Number = 0 Then
'c'est une part
Set lapart = part_doc.Part
Else
'c'est un produit
Err.Clear
Dim pdt_doc As ProductDocument
Set pdt_doc = CATIA.ActiveDocument
Dim pdt As Product
Set pdt = pdt_doc.Product
Dim lesprods As Products
Set lesprods = pdt.Products
Set lapart = lesprods.Item(1).ReferenceProduct.Parent.Part
End If
'Recuperation du nom de la part multi corps et création du produit correspondant
Dim Prod_doc As ProductDocument
Set Prod_doc = les_docs.Add("Product")
Prod_doc.Product.PartNumber = lapart.Name
If Err.Number <> 0 Then
MsgBox "Renommage du document créé impossible" & vbCrLf & "Vérifiez si un document avec un nom identique ne figure pas déjà dans la session..."
CATIA.DisplayFileAlerts = False
CATIA.Documents.Item(Prod_doc.Name).Close
Err.Clear
Exit Sub
End If
'Recuperation des Body non vide , creation d'une part dans le product , renommage de la part et Copier Coller Avec ou sans lien
Dim Msg, Style, Title, Response, nombody As String
Msg = "Souhaitez-vous des liens entre pièces?"
Style = vbYesNo + vbDefaultButton2 ' Définit les boutons.
Title = "Associativité... " ' Définit le titre.
Response = MsgBox(Msg, Style, Title) ' Affiche le message.
For i = 1 To lapart.Bodies.Count
If lapart.Bodies.Item(i).InBooleanOperation = False And lapart.Bodies.Item(i).Shapes.Count <> 0 Then
nombody = lapart.Bodies.Item(i).Name
If InStr(nombody, "\") <> 0 Then nombody = Replace(nombody, "\", "_")
Prod_doc.Product.Products.AddNewComponent "CATPart", nombody
If Response = vbYes Then
' L'utilisateur a choisi des liens.
CCLV2 Prod_doc.Product, lapart.Bodies.Item(i), Prod_doc.Product.Products.Item(Prod_doc.Product.Products.Count)
Else
' L'utilisateur a choisi pas de liens
CCLV1 Prod_doc.Product, lapart.Bodies.Item(i), Prod_doc.Product.Products.Item(Prod_doc.Product.Products.Count)
End If
End If
Next
Prod_doc.Product.Update
End Sub
Public Sub CCLV1(Context As Product, i_object_to_copy, CibleProd As Product)
Set oselection = Context.ReferenceProduct.Parent.Selection
Set oTargetPart = CibleProd.ReferenceProduct.Parent.Part
oselection.Clear
oselection.Add i_object_to_copy
'MsgBox oSelection.Count & ObjtoCCLname
oselection.Copy
oselection.Clear
oselection.Add oTargetPart
oselection.PasteSpecial "CATPrtResultWithOutLink"
End Sub
Public Sub CCLV2(Context As Product, i_object_to_copy, CibleProd As Product)
oselection.Clear
oselection.Copy
oselection.Clear
oselection.PasteSpecial "CATPrtResult"
End Sub
Please can you help me ?
Do you have a macro that could do what I need ?
Best regards,
Jordan Caron
so you are asking to create instances of the three unique parts; are the 1000 bodies named in relation to the three parts, or are you planning on measuring the individual bodies to determine the three unique parts?...
regards,
LWolf
HI LWOlf,
I have 1000 bodies, but in the CATPRODUCT I would love to have instances of the 3 parts , you are right.
Basicaly I would love to have a macro that identify the 3 different geometry from all the bodies present in the ALLCATPART and create 3 parts to be instancied in a CATPRODUCT at the same position than the bodies in the ALLCATPART.
I don't know if I make myself clear.
I don't think it's doable. If this is a one-time task do it manually (possibly with little helper macros).
Your macro creates 1000 unique parts with geometry pasted in the same position as in all.catpart. That's like designing a front wheel of a car while standing at it's trunk in the back.
That looks ok, but is an absolute mess to work with. In reality geometry should be pasted at origin of part's local axis system and then the whole part instance should be moved to match original position.
The fundamental problem here is not only to identify similar part bodies, but to calculate how they are positioned.
I guess you could try creating a footprint of a body by calculating center of gravity for it's generative geometry (i.e. for each vertex, edge and face inside a body), normalizing it (picking one CoG as body's local axis system origin and translating all other CoGs accordingly) and building a local axis system. Then find matching footprints to identify similar bodies (with respect to possible rotation).
Then copy-paste one of matching bodies to a part and move the result to part's origin.
Finally start instantiating parts and move and rotate instances based on original footprints.
If there's no rotation at all (similar bodies differ only by position) then it becomes a bit easier to do.
Thanks a lot Little Cthulhu,
I thought about what you said and I will do it in 3 steps.
STEP 1 : : Transfor the ALLCATPART in CATPRODUCT
Here I use the macro below, that will create a product with 1000 unique parts with geometry pasted in the same position as in all.catpart.
STEP 2 : : Get the center of gravity of every part refering to the product axis system
STEP 3 : : Create a new CATPRODUCT and add instance of the CATPART in the right position, based on the point I got in step 2
So for the step 1, the macro below is working.
FOr the Step 2 I'm facing some issues. I tried this but it is not working :
Sub Main()
Dim Main_Product As Product
Set Main_Product = CATIA.ActiveDocument.Product
Dim AxisComponentsArray(11)
Dim Tab_Result(1 To 100, 1 To 13)
For i = 1 To Main_Product.Products.Count
Instance_Name = Main_Product.Products.Item(i).Name
Set Position1 = Main_Product.Products.Item(i).Position
Call Position1.GetComponents(AxisComponentsArray)
Tab_Result(i, 1) = Instance_Name
Tab_Result(i, 2) = AxisComponentsArray(0)
Tab_Result(i, 3) = AxisComponentsArray(1)
Tab_Result(i, 4) = AxisComponentsArray(2)
Tab_Result(i, 5) = AxisComponentsArray(3)
Tab_Result(i, 6) = AxisComponentsArray(4)
Tab_Result(i, 7) = AxisComponentsArray(5)
Tab_Result(i, 8) = AxisComponentsArray(6)
Tab_Result(i, 9) = AxisComponentsArray(7)
Tab_Result(i, 10) = AxisComponentsArray(8)
Tab_Result(i, 11) = AxisComponentsArray(9)
Tab_Result(i, 12) = AxisComponentsArray(10)
Tab_Result(i, 13) = AxisComponentsArray(11)
End Sub
Could you help me with this ? this code is not working
I have also this code in CATVBA that will display the mass and the point of inertia of a product.
But I need the point of inertia of each CATPART ...
Could you help me to compile such a code ?
Sub CATMain()
' Retrieve the selected component
Dim oSelection As Selection
Set oSelection = CATIA.ActiveDocument.Selection
Dim oProduct As AnyObject
Set oProduct = oSelection.FindObject("CATIAProduct")
If (Err.Number <> 0) Then
MsgBox "No selected product"
Else
On Error GoTo 0
' Compute the inertia
Dim oInertia As AnyObject
Set oInertia = oProduct.GetTechnologicalObject("Inertia")
' Read the inertia data
Dim dMass As Double
dMass = oInertia.Mass
Dim dCoordinates(2)
oInertia.GetCOGPosition dCoordinates
' Display the results
MsgBox oProduct.Name & ": Mass = " & CStr(dMass) & ", Center of gravity : X = " & _
CStr(dCoordinates(0)) & ", Y = " + CStr(dCoordinates(1)) & ", Z = " + CStr(dCoordinates(2))
End If
End Sub
your step2 code needs end of the for loop...
so just write "next" before the "End Sub" line
regards,
LWolf
Sub Main()
Dim position1
Dim k As Integer
k = Main_Product.Products.Count
ReDim Tab_Result(1 To k, 1 To 13)
Instance_Name = Main_Product.Products.item(i).name
Set position1 = Main_Product.Products.item(i).Position
position1.GetComponents AxisComponentsArray
Tab_Result(i, 13) = AxisComponentsArray(11)​
Next
End Sub
regards,
LWolf
