VBA- Create edge fillet failing
appvid
Automotive
I have an issue with creating edge fillets
Goal is to create fillet on sharp edges on a join surface. The join surface has several hundred faces and shapr edges.
Script fails at -----
shapeFactory1.AddNewSurfaceEdgeFilletWithConstantRadius(bumpsref(1), catTangencyFilletEdgePropagation, 0.2)
Could one of you help me out. Thank you..
here is my script
Sub CATMain()
Dim partDocument1 As PartDocument
Set partDocument1 = CATIA.ActiveDocument
Dim part1 As Part
Set part1 = partDocument1.Part
Dim selectionbody As selection
Set selectionbody = partDocument1.selection
selectionbody.Clear
Dim InputObject(0)
InputObject(0) = "HybridShape"
Set Bodyforfillet = CATIA.ActiveDocument.selection
MsgBox "Select Surafece wih bumps"
Status = Bodyforfillet.SelectElement2(InputObject, "Select Surface for fillets", False) 'Selection
Set bodyname = selectionbody.Item(1).Value
MsgBox bodyname.Name
Dim Bodyslection As selection
Set Bodyslection = CATIA.ActiveDocument.selection
Bodyslection.Search "type=topology.face,sel"
MsgBox Bodyslection.Count2
MsgBox Bodyslection.Item(2).Name
'selectionbody.Clear
Dim bumps As Integer
bumps = Bodyslection.Count2
Dim bumpsref() As Reference
ReDim bumpsref(1 To bumps)
For i = 1 To bumps
Set bumpsref(i) = Bodyslection.Item(i).Reference
'MsgBox bumpsref(i).Name
'Dim oface As Face
'Set oface = Bodyslection.Item(i).Value
'Dim Pillow_ref As Reference
'Set Pillow_ref = part1.CreateReferenceFromBRepName(bumpsref(i).Name, oface.Parent)
Next
Bodyslection.Clear
'-------------------------------------- Adding fillets
Dim shapeFactory1 As ShapeFactory
Set shapeFactory1 = part1.ShapeFactory
Dim constRadEdgeFillet1 As ConstRadEdgeFillet
Set constRadEdgeFillet1 = shapeFactory1.AddNewSurfaceEdgeFilletWithConstantRadius(bumpsref(1), catTangencyFilletEdgePropagation, 0.2)
For i = 2 To bumps
constRadEdgeFillet1.AddObjectToFillet bumpsref(i)
Next
constRadEdgeFillet1.FilletBoundaryRelimitation = 1
constRadEdgeFillet1.EdgePropagation = catTangencyFilletEdgePropagation
constRadEdgeFillet1.FilletBoundaryRelimitation = catConnectFilletBoundaryRelimitation
constRadEdgeFillet1.FilletTrimSupport = catTrimFilletSupport
End Sub
Youd should select the edges not the faces ,try
Bodyslection.Search "type=topology.edge,sel"
part1.Update
End Sub
Tudor
