Tire Modelling 1
masterymw
Automotive
NP
I have tried to model the motorcycle tire in Adams view in which I gave input the area moment of inertia Ixx,Iyy, and Izz ( polar moment of inertia ) and I used pac2002_175_70R13.tire. I had expected that the tire and rim model will look like a motorcycle tire assembly but it looks like a car's tire assembly having a greater thickness. Also is there any way so that we can also made tire tread? and what about the spokes wheel? can we model the wheel with spokes too?
a 175_70R13 tire is a car tire, quite a small one these days.
No, you can't model a spoked wheel, easily, but you can import a suitable 3d model of one for the graphics. Not something I've bothered with. Basically you'd create a graphics object and connect it to the wheel part with a fixed joint.
Cheers
Greg Locock
So which model do I need to use to model the motorcycle tire?
Thanks for your valuable suggestion !!!
Getting hold of tire data is rather hard. Typically a decent tire test costs tens of thousands of dollars, and wrecks half a dozen tires. I wonder if perhaps one of Tony Foale's books or a google search on pacejka model motorcycle tire would lead you to some better numbers?
Cheers
Greg Locock
There are so many tire models in Adam's library. I doubt all of them are only for the car because some models are lool like motorcycle tire assembly geometrically. And another thing, I guess tire tread pattern also plays a role in the analysis. But I haven't seen the tread in the geometrical model. Maybe, It is taken into account in somehow in the model without representing visually.
Tread pattern is not represented by the tire model. The tire model is effectively an n dimensional fit to a series of tests, it just spits out 3 forces and 3 moments in response to 6 inputs. Again you could import a pretty picture of a tire to overlay on the wheel, it wouldn't deform.
Cheers
Greg Locock
Thank you for your suggestion!! [dazed]
