I have a similar situation as posted in thread338-42599 - I have an iron fence mounted in a low cement wall that borders on a park. The park uses sprinklers nightly with treated water. After one year, the fence is showing significant corrosion where it enters the concrete and light corrosion elsewhere. Would it help to paint the fence with a zinc primer and screw on Mg anodes? Will grounding the fence impact the corrosion?
