Modeling CSTR in series for a membrane reactor: MATLAB
Dear all,
I'm new to modelling in Matlab, and am trying to model a hollow fibre membrane separating water and BSA using the tank in series model.
For this, I have determined that the number of CSTRs (found to be 44 through tracer experiments) that represent the membrane.
Now I am having difficulties inputing the ODE for the water balance.
The following assumptions are made:
- BSA and water enter the feed
- ONLY water permeates through the membrane
- the retentate stream has BSA and water.
For the water balance, I simply have:
dn/dt = Fw,in - Fw,out - J*A
where Fw,in and Fw,out are the molar flow of water [mol/s] in and out of the CSTR, J is the flux [mol/s*m2] and A the surface area of the membrane.
However, when I input this as an ode45 into matlab, matlab processes the equation as dFw/dt rather than dn/dt.
Therefore, how do format my water balance so that the inlet and outlet variable that are changing are in mol rather than mol/s?
RE: Modeling CSTR in series for a membrane reactor: MATLAB
