Bearing Pressure of Cantilever Retaining Wall 1
Sylus
Automotive
Jul 27, 2020
4
Example: I have a cantilever retaining wall in soil (like in the attached photo), and I am looking to check the soil bearing pressure. I know the net ultimate bearing capacity of the soil and I also know that by the definition of net bearing pressure, only the additional weight is considered (that the weight of the soil above has already been included). In the bearing pressure calculations you need to find the sum of the moments at the base as well as the sum of the axial loads, which then in turn gives you your eccentricity which is used to find the total bearing pressure at the base [URL unfurl="true"]https://trackeasy.fun/usps/[/url] [URL unfurl="true"]https://showbox.tools/[/url].
My questions is this: when does the weight of the soil (and wall) get considered in the calculations? It would make the most sense to me that the eccentricity is calculated considering all loads (soil above the toe and heel of the retaining wall as well as the self weight of the wall itself), but then the bearing pressure at the base is calculated using this eccentricity, but the axial load used in the bearing pressure calculation would be only the portion of the wall above grade (on either side), along with any soil weight that is above the grade on the other side of the wall. This makes the most sense to me as the soil and wall weight need to be considered for the appropriate eccentricity calculation, but as I am checking against the net bearing pressure, the soil above should not be considered. Please let me know any thoughts or questions you may have.
Here is a typical retaining wall case - check rotation about toe point "O", and check maximum bearing stress against allowable; also need to check against sliding.
Further to the image from @r13, don't forget any hydrostatic pressure and external surcharge (if any). Apart from getting the acting vs resisting forces correct, an appropriate selection of coefficient of lateral earth pressure is equally important.
