Removal of 3 Layer Polyethylene on pipeline under water
What is the ramification of removing 3 Layer Polyethylene on pipeline under water (offshore) to accommodate AUT inspection? Is it a common practice? Must the coating be removed to perform AUT inspection?
RE: Removal of 3 Layer Polyethylene on pipeline under water
The pipe is much more likely to corrode?
What AUT are you doing?
Most UT I know will account for the thickness of the external coating.
This sounds very odd to me. How are you raising the pipeline off the seabed?
Suppose you are carrying out AUT on overhead insulated piping. You remove the insulation, then do the AUT.
Same logic.
DHURJATI SEN
I wouldn't say that it is a common practice to deliberately damage the primary barrier to corrosion, particularly if the line can take ILI. It will be an expensive measure as the stuff doesn't come off easily.
Steve Jones
Corrosion Management Consultant
www.linkedin.com/in/drstevejones
All answers are personal opinions only and are in no way connected with any employer.
Also "AUT" covers a multitude f different systems.
What and why are you doing it?
dhurjati - I don't agree this is the same thing.
3LPE is not designed to be removed and looses most is not all of it's properties of you do. Plus there should be no need.
What does the inspection company say?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
The Low-Code Digital Transformation Guide
Change the way you develop apps and, in turn, change the way your business operates and engages with customers, leading to new channels of revenue. This ebook is the culmination of 14 years of experience with 4,000 customers that have all transformed their business through low-code development. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
