mortezanazari
Dear friends,
Hope all is well,
I am designing several classical venturi flowmeter based on ISO 5167-4 standard. There is a table for required straight length for classical venturi tube when it is used without flow conditioner. However, I could not find any information in case of used with flow conditioner / straightening vanes.
I would be very grateful if you can help me with a solution to find out the required straight length when there is a flow conditioner/straightening vanes upstream of venturi tubes.
Thank you,
Morteza
Hope all is well,
Thank you,
Morteza
