As civil and structural engineers, when you get to repair a residential building damaged by flood, vehicle impact or any other type of incident, how do you deal with the non-conformity with the current building code? Sometimes the damage is minimal (e.g. a couple of wall studs) but the foundtion or the roof above it doesn't conform to the code. How are you going to put these non-conforming members in your repair drawings? Especially in those houses where if you start upgrading to the code, you won't finish before replacing a large portion of the building! How do codes in North America (U.S.A and Canada) deal with that?
