Contact US
Stress testing 3.2V 100AH LiFePO4 cells for RV/marine use
Hi Everyone,
First post here. I know many of you are miles ahead of me, and I probably should have read a dozen rules about where to post and what format to use, so please forgive and know that I'm posting this humbly and hoping for some (kind) input. I have an old EET degree that I never really put to use because I spent my career raising money for kids to get scholarships for EET and EE degrees, and I've forgotten more than I've learned, but I'm catching up quick lately on account of wanting to put a ~20kW LFP bank in my new 2020 awd high roof transit w/2" lift, bigger tires, etc. I plan to have a 250A 24V alternator.
That has me interested in the science of LiFePO4 at high temperatures. I've read a number of detailed studies by minds far greater than my own, but in the meantime, I've got the plant director of a small lithium battery manufacturer in China sending me two 3.2V 100AH prismatic LiFePO4 cells so that I can stress test them myself. I'm mostly interested in how the cells perform at higher temperatures (40C-70C), with the relatively low charge (0.33C) and discharge rates (0.5C, 03C, 0.2C, and 0.1C) common in RV use (marine can perhaps be a bit higher).
When the time comes and I order the larger battery bank, I'll have a 6kW sigineer inverter/charger, and the 250A 24V alternator + wakespeed regulator, but at the moment, I don't have the means to charge/discharge single cells, or at most the two 3.2V 100AH cells in series or parallel.
Any recommendations that don't break the bank, since I won't be reusing the test equipment very often, if at all?
I found a small ~$118 charge/discharge unit on Amazon that looks like it'll get ballpark 0.5C discharge rates (it's only 150W max), but I think it may only charge at 3.2V 5A. I'm asking the maker if the 22V 5A charge spec is the upper limit on each of those, but I think it is, so even though 22x5=110W, I can't instead do 110W/3.2V=34A or 0.34C, which would be perfect. I'm beginning to understand amp ratings are fixed on most low end variable dc power supplies. Here's the unit. Any thoughts?
https://smile.amazon.com/Digital-Batter ... B08CF2ZYC7
For low budget discharging, I have another idea, but please tell me if this is nuts. I believe I can buy 4 x 100W 0.3Ohm wireround resistors, and put them in parallel, to get the resistance down to 0.075Ohm. At ballpark 3.5V fully charged (or maybe it'll be 3.65V?) I'm assuming 3.5/0.075Ohm=47A discharge current, which 4 x 100W resistors (400W) should be able to handle, right? 3.5x47A=~165W. Is a circuit like this too unstable and unpredictable?
If not, great. The resistors are only about $20 for 4 of them.
If it is a nutty idea doomed to failure, then I assume then I'll need a DC electronic load discharge device. The KP184 rated to 400W looks like it could work. But $175-$200 is a lot for a device I'll only use a few times. I guess I could ebay it afterwards. https://smile.amazon.com/Single-Channel ... 07Z4Q9JWV/
For low budget charging, I'm really stuck. I keep finding 10A max variable dc power supplies, or that first charge/discharge unit that I believe may only be 5A, nowhere near the 33A/0.33C charge rate I'd like to test. Any ideas on how to charge a 3.2-3.65V 100AH LFP cell at 0.33C/33A without spending a fortune? It's crazy how 12V 500A power supplies are a dime a dozen, but trying to get 100A at 3.5V requires diamonds and gold bars. For a minute I thought I could use the same resistors to voltage divide my way into using a 12V power supply, but I'm beginning to realize that's just too dangerous and likely to damage the cells before I get to the real reason I'm doing all of this -- high temperature stress testing.
Assuming I eventually solve the charge/discharge part without spending $1400 on a used Cadex C7400ER-C (ain't gonna happen), then comes the more dangerous part: stress testing the cells while still gathering measurements without injuring myself or others. I'm a bit of a dukes-of-hazard billy-the-kid type, so I'll figure it out or die trying, but I'd much rather get some guidance from others who know more than I do before I say screw it and start blowing sh!t up. I Also emailed my colleagues at the local EE department where I helped raise money for students and faculty for many years, so we'll see if they have interest or let me use some of their equipment.
But assuming they have no interest due to safety/insurance/covid, etc, my first thought was to build a metal box and set it in the sun, which just a month ago would have hit 40-60C easily. But it's already getting down to 30C ambient in September, so I'll be lucky to hit 40C in the box.
So how about using my portable $100 walmart radiant "oil" heater I use in the winter. It's fully passive, no glowing coils, just a quiet and slow but steady radiating heater. I could set a metal box on top of it with some ceramic fiber under it to isolate it a bit, turn it on low, measure the temp in the box, figure out how much venting will get the box at 40C, or 50C, etc, depending on the test, then put the battery in the box with the discharge unit next to it but down on the ground shielded from the heater. Take measurements with my fluke 32 at set time intervals (cover my skin and wear a helmet?).
It's ghetto science, but hey, I want the data. Will these cells expand, leak electrolyte, smoke/fire, etc at 0.33C charge and 0.5C discharge at 40C, 50C, 60C, 70C? I don't plan to overcharge or over-discharge, because that's not planned usage, but if my van's a/c system, with active fan venting backup fails, and the big 20kW bank I buy is sitting in the van in the sun while I'm off backpacking for 5 days on a 40C ambient day with 60-70C inside the van, I want to know what these cells will do. Granted they'll be new, and any data I gather won't apply to the same cells in 3-5 years, but at least I'll have a starting point for the upper/lower thresholds that isn't based on some battery manufacturer's statements, but based on real world observations and testing. I was born with "I'll believe it when I see it" stamped on my forehead.
Please help. I'll buy you a 6-pack someday!
RE: Stress testing 3.2V 100AH LiFePO4 cells for RV/marine use
As IR mentioned, this forum is for working professionals about work related things.
I suggest you try this question in https://diysolarforum.com/forums/vehicle-mounted-systems.7/ Where there are lots of helpful people and the guy who started this forum lived with solar power in an RV for almost a decade. He also sells a DIY for vehicles book that is widely enjoyed.
Keith Cress
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
