I'm building a makeshift portable "generator" for powering essential appliances during power cuts (basically a modem(5W), desktop PC (200W), fan (40W) and possibly fridge (160W) on occasion). It will essentially consist of a battery and a 500W (continuous) pure sine wave inverter that I carry around the house as needed.
Based on being able to run the fan (most essential load) for a 4-hour powercut, energy needs are 40W*4h = 160Wh. Factor in 90% inverter efficiency and 80% depth of discharge and you get battery capacity of 160 / 0.9 / 0.8 = 222Wh. Divide by 12V and you get 18Ah. Add a bit more for safety and it means 25-40Ah of battery should do it. I'm targeting battery weight of under 10kg to make it easy to haul around. The battery will be stored disconnected and charged infrequently. It will be used every few months when there's a power cut, for however long it takes for electricity to come back (2 hours on average).
I tried looking into LiFePO4 batteries, but most good-value online companies don't ship to Malta (Europe), and all the logistics companies wouldn't touch lithium batteries with a 10-foot pole (dangerous goods, ADR declarations etc.). A lot of them claim they're working on giving me a shipping quote and then... silence.
So I'm basically stuck looking at locally-available small/medium-size deep-cycle lead-acid batteries. The thing is, there are a lot of choices with similar prices and specs. Especially within the same company's own lineup, they offer multiple series with cryptic names (such as "CP series" or "CPL series") but the product description is more marketing lingo than a technical description of, say, what makes the "CPC" series good for cycling applications while the "CPL" series has a longer life and "CPR" have high vibration resistance for railways...
I was wondering if you battery experts could help me identify the best battery for my application, and maybe explain a bit how they design a battery to have long life, or high cycles, or high discharge, and what makes a "traction" battery.
Here's my shortlist of the four locally-available batteries under consideration (prices are local prices, links are to manufacturer page for that model):
1. Victron SuperCycle AGM 24Ah. €100. Battery description here, datasheet here.
2. Cellpower CPL 28-12IA long-life AGM 28Ah. €130. Link
3. Cellpower CPC 33-12 cyclic AGM 33Ah. €133. Link
4. pbq HR22-12 high-rate AGM 22Ah. €94. Link
I'm most impressed by the Victron in terms of company literature (#1) but the Cellpower long-life (#2) seems to be the best fit for my application. Thoughts?
